JohnAlbert's avatar
JohnAlbert
Follower
Apr 20, 2017
Orbi placement & power level questions
Hello all -
I don't yet have an Orbi, looking to purchase a router/satellite soon to replace an old Airport Extreme for use in a Mac/iOS environment.
I've been following the progress of Orbi (as well as the other "mesh-style" systems) for a few months now, looks like Orbi will be my choice, but a few questions.
I'll be using it in a 2-story home, not large, about 730sq.ft. downstairs and the same upstairs. Orbi router will be in the center of house downstairs, and satellite will be diagonally overhead upstairs. There will of course be a ceiling (plaster and lathing) between them, but the actual distance will be around 15 feet.
I've read that there is a -minimum- distance the router and satellite should be placed, to avoid signal conflicts. Will "15 feet and a ceiling" be too close together? I might be able to increase it to 20+ feet, but not much more than that.
I've read that the signal output strength is user-definable. I'm wondering if I could actually set the signal strength for both router and satellite "down" somewhat, say to 75%? Does the control interface permit this?
Perhaps I could "get by" by using the router only (downstairs), which is how I have things setup now with the AE. But I'll still buy the router/satellite package, to have the satellite available for future use if needed.
1 Reply
  • I don't have 2.4GHz devices I have turned that radio off, the 5ghz is set to 75% and beamforming off.  however I have not been able to find a way nor do I know a way to turn off or lower power on satellite itself been only be able to on the main unit.  For a 730 Sq ft house you might be ok without need a satellite you may have to test and experiment what works for your particular environment and surrounding.
