QQQQ
Jul 08, 2018Aspirant
Orbi port forwarding not working on multiple ports
My Orbi rbk33 system is working fine and I’ve upgraded to the latest firmware. I have several foscam IP cameras which I had port forwarded in my old system so I could see them remotely.
The fir...
- Jul 09, 2018
It should be on the page where you select the service you are forwarding. Take a look at page 106 in the manual here. (Assuming this matches your firmware.)
https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
OR, See the notes in this thread about needing to go back and change the service name from http after setting up the first forwarding rule:
https://community.netgear.com/t5/Orbi/Orbi-RBR50-Port-Forwarding-Not-Working/td-p/1484088
Jul 09, 2018Guru - Experienced User
What broswer are you using?
When you have applied the 1st configuration, have you restarted the router, then try to set up the next configuration?
- QQQQJul 09, 2018Aspirant
Yes, I've rebooted the router and I've tried this on my iPad and my desktop using both Safari and Chrome.
Also, if I have 8 ports to forward and they are all different IP locations, it seems rather silly to have to reboot the router in between each time.
On my ASUS router I can easily forward multiple ports and then reboot once at the end so I am not sure what's going on now and/or what I might be doing wrong.
