QQQQ
Jul 08, 2018Aspirant
Orbi port forwarding not working on multiple ports
My Orbi rbk33 system is working fine and I’ve upgraded to the latest firmware. I have several foscam IP cameras which I had port forwarded in my old system so I could see them remotely.
The fir...
- Jul 09, 2018
It should be on the page where you select the service you are forwarding. Take a look at page 106 in the manual here. (Assuming this matches your firmware.)
https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
OR, See the notes in this thread about needing to go back and change the service name from http after setting up the first forwarding rule:
https://community.netgear.com/t5/Orbi/Orbi-RBR50-Port-Forwarding-Not-Working/td-p/1484088
