totolita
Sep 22, 2018Aspirant
Orbi port forwarding problem
Hi, I'm having problems with port forwarding. I did this before so simply with an Asus router but I'm getting frustrated here!
I have a public static IP with my ISP provider, I have checked that t...
Sep 24, 2018Guru - Experienced User
What FW is currently loaded?
When uPnP is enabled, be sure to disable any Port Fowarding configurations. You may also try to set NAT Filter to Open and test as well.
Besure to set up an IP address reservation ON the router for the NAS.
- totolitaSep 24, 2018Aspirant
FW is 2.1.4.16
Modem mfr Technicolor (I don't see how this could be an issue since I had it connected to the Asus and working perfectly)
When I had upnp enabled I disabled the port forwarding. The NAT Filter is disabled on the modem from my ISP since it is linked to a static public IP, so they let it open. So I have NAT enabled on my Orbi, otherwise I would be out in the open right? I have all my devices with reserved DHCP including the NAS.
