totolita
Sep 22, 2018Aspirant
Orbi port forwarding problem
Hi, I'm having problems with port forwarding. I did this before so simply with an Asus router but I'm getting frustrated here!
I have a public static IP with my ISP provider, I have checked that t...
totolita
Sep 24, 2018Aspirant
FW is 2.1.4.16
Modem mfr Technicolor (I don't see how this could be an issue since I had it connected to the Asus and working perfectly)
When I had upnp enabled I disabled the port forwarding. The NAT Filter is disabled on the modem from my ISP since it is linked to a static public IP, so they let it open. So I have NAT enabled on my Orbi, otherwise I would be out in the open right? I have all my devices with reserved DHCP including the NAS.
Sep 24, 2018Guru - Experienced User
There a model # of the modem? Just checking for router here is all.
- totolitaSep 24, 2018Aspirant
TC 7300
- FURRYe38Sep 24, 2018Guru - Experienced User
I believe your modem is a modem/router combo:
https://fccid.io/H8N-TC7300/User-Manual/User-Manual-TC7300-d1TI-rev-pdf-2662571.pdf
This can effect Port usage and NAT on the Orbi.
I would try 1 of the following:
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.- totolitaSep 26, 2018Aspirant
Tks for the answer, sorry for the delay, busy busy. Regarding your proposed options I tell you here what I've done without success yet:
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. NOT AN OPTION ACCORDING TO THEM, THE PUBLIC STATIC IP SHOULD DO.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode. THIS I'VE DONE SINCE THE BEGINNING (DISABLE WIFI RADIOS) SINCE I DIDN'T WANT THE INTERFERANCE WITH THE WIFI OF MY ROUTER. I ALREADY SET THE IP OR THE ORBI (IT GETS 192.168.0.3 FROM THE MODEM) AS DMZ. NO CHANGE AT ALL, PLEX STILL UNAVAILABLE FROM OUTSIDE.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. FOR ME THIS IS NOT AN OPTION, THE MODEM HAS NO DHCP RESERVATION ADMIN (MAIN ISSUE) AMONG OTHER OPTIONS FROM ROUTER.I appreciate your help, I'm getting very frustrated specially because I had it working perfectly before. Any more ideas???
Tks
