totolita
Sep 22, 2018Aspirant
Orbi port forwarding problem
Hi, I'm having problems with port forwarding. I did this before so simply with an Asus router but I'm getting frustrated here!
I have a public static IP with my ISP provider, I have checked that t...
Sep 26, 2018Guru - Experienced User
Besure to disable any Firewalls on the ISP modem. Even though DMZ should work ok on the Modem as well.
You can try setting NAT Filter to OPEN on the Orbi router and see if this helps.
totolita
Oct 01, 2018Aspirant
Hi, tks for the idea, but how do I know that I'm not in the open with this? I mean, how do I know that my router has NAT enabled? I only see NAT SIP ALG options (a lot of them), not a general NAT rule. Is this enough?
- FURRYe38Oct 01, 2018Guru - Experienced User
All routers and modems with routers are NAT by default. When in AP mode on the Orbi, then NAT is disabled.
http://computer.howstuffworks.com/nat.htm
http://www.practicallynetworked.com/networking/fixing_double_nat.htm
http://www.dslreports.com/shownews/Networking-101-The-DMZ-137550
- totolitaOct 03, 2018Aspirant
Hi, well I tried your suggestion and it still doesn't work. I'm giving up. I'll rebuy the Asus router.
- FURRYe38Oct 03, 2018Guru - Experienced User
Probably a modem/router combo issue. If the DMZ was configured right on the modem, and uPnP is enabled on the Orbi, it's all thats needed.
Good Luck.
