totolita
Sep 22, 2018Aspirant
Orbi port forwarding problem
Hi, I'm having problems with port forwarding. I did this before so simply with an Asus router but I'm getting frustrated here!
I have a public static IP with my ISP provider, I have checked that t...
Oct 01, 2018Guru - Experienced User
All routers and modems with routers are NAT by default. When in AP mode on the Orbi, then NAT is disabled.
http://computer.howstuffworks.com/nat.htm
http://www.practicallynetworked.com/networking/fixing_double_nat.htm
http://www.dslreports.com/shownews/Networking-101-The-DMZ-137550
totolita
Oct 03, 2018Aspirant
Hi, well I tried your suggestion and it still doesn't work. I'm giving up. I'll rebuy the Asus router.
- FURRYe38Oct 03, 2018Guru - Experienced User
Probably a modem/router combo issue. If the DMZ was configured right on the modem, and uPnP is enabled on the Orbi, it's all thats needed.
Good Luck.
