nickavem
Apr 13, 2021Aspirant
Orbi port fowarding stopped working
Hardware Version RBR50 Firmware Version V1.4.0.34 GUI Language Version V1.0.0.284 Operation Mode Router Hello. I got my orbi a couple of mont...
- Apr 13, 2021
The issue sounds a lot like the ISP device changed from being "only a router" to a combination "modem/router".
When the Orbi is given a WAN IP address starting with 192.168.1, it automatically switches the IP subnet on the LAN side of the Orbi to 10.0.0.x In a "Double NAT" situation, Orbi can forward all the ports it wants to, but the connections will never reach the Orbi because the ISP router will block them. See https://kb.netgear.com/30186/What-is-Double-NAT
There are two recommended solutions:
- Place the ISP device into "modem only" or "bridge" mode. This will leave the Orbi as the only router and port forwarding will work again.
- Place the Orbi into Access Point mode and set up port forwarding on the ISP router. Most routers have basically the same capabilities, so most routers can do this.
My own choice would be #1.
nickavem
Thanks for the timely reply! What would be the easiest way to access the ISP router's interface? The adress I used previously does not seem to work when connected to orbi. Should I just direct connect to the previous router?
CrimpOn
Apr 13, 2021Guru - Experienced User
nickavem wrote:Thanks for the timely reply! What would be the easiest way to access the ISP router's interface? The adress I used previously does not seem to work when connected to orbi. Should I just direct connect to the previous router?
Yes, to mess with the ISP device, connect directly to it if you can.
