fruitypigy
Feb 12, 2017Guide
Orbi Portforwarding Not Working
I reccently got a new orbi router and have been having issues with portforwarding. I just tried making a minecraft server and everything is fine but something with the port forwarding is wrong. I use...
- Jul 09, 2017
if you are port forwarding you need to disable UPnP
Mikey94025
Feb 12, 2017Hero
Getting the port tester to work is a good start... Something isn't working right. Is your Orbi in Router or AP mode? Does your cable modem also had port forwarding for 25565 and if so, is it forwarding that port to the IP of your server? If your server IP changed then port forwarding that worked with your old router will probably not work with your new one.
- fruitypigyFeb 13, 2017Guide
Thanks for the reply
However I belive my router is in AP mode though I'm not sure how to check, I didn't know modems needed to be portforwared (do I simpy plug my ethernet cable from my computer to the modem?), and don't know what a server IP is.
Thank you so much
Sorry for the ignorence :mantongue:
- TheEtherFeb 13, 2017Guru
If your Orbi is in AP mode, then you don't need to worry about setting up port forwarding on it. You need to configure port forwarding on whatever device is operating as your router. That could be your modem, which might have a router built into it.
I actually may have misread the information. I believe my router is not in AP mode. Its operation mode is router but earlier I had read wireless settings
