buchi4061's avatar
buchi4061
ORBI position
HI
I have an Orbi Satellite and router ( RBK50)  and live in a 2 storey house.
The router is situated downstairs next to NBN connection point and the Satellite  upstairs connected to Sony smart TV.
The house is not that big in length approx 25m ...
The issue i am is that coverage ok ( 47mbps) within 5-10 m of the satellite  upstairs but when i move to the end of the house speeds decrease. There is 3 walls made of gyprock..I get approx 47mbps near the satellite but this drops to 5 mbps
Could anyone suggest what the issue maybe that i cant get the covreage from this mesh system.
Appreciate the assistance.
Steve
1 Reply
  • What Firmware version is currently loaded?
