JPCMH
Jun 04, 2017Initiate
Orbi Power Adapter Design
After a pretty in-depth decision process, I selected the Orbi for my home office. It was delivered Friday. I was pretty impressed with the design until I opened the power adapters, which are the dumb...
mahughesnh
Sep 09, 2017Guide
I also think it is a stupid design. I used a workaround to connect my satellite because it would not allow the cabinet I had it sitting on to sit as close to the wall as I wanted.
martyfp
Sep 11, 2017Luminary
dito - I ended up having to plug an extension lead into the socket, put the extension lead under the cabinet with the adapter plugged into it, then run the orbi power lead back up behind the cabinet to the satellite. It works but somewhat ungainly.
