sfobcn
Dec 14, 2016Aspirant
Orbi Power Adapter Voltage Label
Does the the Orbi Wifi Power Adapter (purchased in America), read 100V-240V on the label? Please advise! Thank you!
genobkk
Dec 14, 2016Star
I bought mine from Amazone shipped from the U.S. I am using it in Thailand we use 220 volts here no issues. Honestly I forgot to read voltage but if it was not 220 it would have fried the power adapter at least in 1 seconds
sfobcn
If you can look at the adapter, I would still appreciate to know what it
reads exactly! I live in Brazil and I bought a Arlo security system in the
US which I was assured (by Netgear support) that it supported dual voltage
and it did not! It did work for like two months and then stopped! That is
when I saw it read 100V to 120V after all (and getting a replacement base
was difficult)! Thanks!
