DCP4971
May 25, 2021Luminary
Orbi Power Cycling
Hi all, We've been having a few ISP issues of late and wondering if this might be causing our Orbi to power cycle. It's running in Router mode, connected to our ISP provided router, It seems to rand...
Jun 02, 2021Guru - Experienced User
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Has a factory reset and setup from scratch been performed since last update?
DCP4971 wrote:Hi all,
We've been having a few ISP issues of late and wondering if this might be causing our Orbi to power cycle. It's running in Router mode, connected to our ISP provided router, It seems to randomly restart every now and again, including this morning (when my wife had started work, so was quite disruptive).
I've been doing some digging and managed to find the UpAgent.log file which shows when the connection drops. I can then see the auto_fw_upgrade_log file which shows an entry 'AUTO FW CHECK: power cycle', at the time that it all went down.
Anyone know if this power cycle can be caused when the internet connection drops, or what else might be triggering it?
I'm on FW 2.7.2.104.
Thanks,
DCP
