ScooterA's avatar
ScooterA
Follower
Oct 25, 2021
Orbi Power Supply (Right Angle Connector)
(1) Do Orbi's all use the same power supply?
(2) Does Netgear make one with a right angle plug (so the Orbi can fit in a limited space)?
(3) If so, how would I acquire one from Netgear?
1 Reply
  • FURRYe38's avatar
    ScooterA wrote:
    (1) Do Orbi's all use the same power supply? No however most are generally the same. Voltage and amps may differ between the Orbi models. Some case styles differ as well.
    (2) Does Netgear make one with a right angle plug (so the Orbi can fit in a limited space)? Yes. There all mostly right angle adapters.
    (3) If so, how would I acquire one from Netgear? Not sure if NG does this, something to ask NG support or a Forum Moderator.
    If you need a plug in adapter that is angled but you already have a adapter, you could use a power plug extension cable that would have a right angle to the cable plug. Look on Amazon or other places on the internet for power extension cables that you can plug the Orbi Power adapter into.
