Ihateuverse
Sep 04, 2018Aspirant
ORBI Problems with Uverse
I have an RBR40 ORBI router system at my home. I have Att Uverse. So I had to change the router into access point mode. I moved into my new home about a month and half ago and I do not have consist...
Sep 04, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Ihateuverse
Sep 05, 2018Aspirant
I have done #3 - where I shut off the wireless output of the ATT router. I have connected the Orbi Router unit to the ATT router. I have the two satellite units spaced out in various places around the home. I have a 5000 sqft home. Hence the reason for purchasing the orbi's. But, it seems that I have to reset the router unit everyday because the two satellites have no output. I can be sitting next to a satellite and run a speed test, and all I get is an error message that no isp is found. I thought maybe the satellites and the router unit may have different firmware on them. So, I tried logging into to the router unit, but I cannot login through orbilogin.com nor can I login through the app.
- FURRYe38Sep 05, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
