bardiferously's avatar
Feb 13, 2018
Orbi Product Comparison
Hi all,
I think an Orbi AC3000 mesh network would be a good solution to have a unified network with some remote ethernet connections.  But....  I'm so confused.
Models:
  • rbk50
  • rbk52w
  • rbk53
  • rbr50
  • rbs50
  • rbs50y
Is there a good comparison that explains the differences between these models?
Help!
  • OK, I think I have got it:
    • rbk50 - AC3000 Kit of router & 1 regular satellite
    • rbk52w  - AC3000 Kit of router & 2 wall satellites
    • rbk53 - AC3000 Kit of router & 2 regular satellites
    • rbr50 - AC3000 router only
    • rbs50 - AC3000 regular satellite only
    • rbs50y - AC3000 outdoor satellite only
    Thanks for the previous reply and any others reviewing.
  • wrote:
    Hi all,
    Models:
    • rbk50
    • rbk52w
    • rbk53
    • rbr50
    • rbs50
    • rbs50y
    Help!
    There's always this page:
    https://www.netgear.com/orbi/systems.aspx
    Note the RBR is a router, the RBS is a satellite.  The RBK variants are kits, router+satellite(s).   The RBS50Y is the new outside satellite.
    • bardiferously's avatar
      bardiferously
