Savid
Jan 04, 2020Aspirant
Orbi purchase help
Need help selecting which Orbi setup I need. My house is about 2,000 sq feet plus I have a workshop about 600 feet away from the house. Thanks
CrimpOn
Jan 04, 2020Guru - Experienced User
The 2,000 sq. ft. house is "no problem" for any number of Orbi models. The 600 ft, however, is WAAAY too far for an Orbi WiFi backhaul signal. Simply will not work. In fact, that distance is technically too far for an ethernet cable (100m max). I would look into a system that has "point to point" connections to bridge two LAN's.
Savid
Jan 05, 2020Aspirant
I saw this on the Netgear website and figured something like this would work.
https://www.netgear.com/orbi/rbs50y.aspx
- michaelkenwardJan 05, 2020Guru - Experienced User
I've got one of those. No way does it stretch 600 feet.
That would get me to the pub on the village green! No chance.
