BigAl01
Feb 27, 2021Aspirant
Orbi Purple Light after ISP change: Resolution
I own an Orbi RBR20 to provide better WiFi coverage in my house. I have been generally happy with the product. I recently changed ISP providers. I set up my new modem and connected to the interne...
BigAl01
Feb 28, 2021Aspirant
Hi CrimpOn:
Having the double NAT was not my original intention. When I first bought the Orbi I had a lot of difficulty setting it up. It was only after hours on the phone with Netgear Tech support that the configuration wound up this way in the first place.
CrimpOn
Feb 28, 2021Guru - Experienced User
Some of us have sort of a mantra, "If it ain't broke, don't fix it." As long as your devices work as they should, there is no need to change anything. Just be aware that there are specific activities that cannot function with two routers.
