sayboon
Jun 12, 2018Tutor
Orbi QoS for Gaming RBK50
Hi Netgear,
Are there any plans or timeline on when QoS will be officially available from a gaming standpoint? FPS gamers out there using Orbi will attest that they'll want priority on device t...
Breggen
Jun 27, 2018Star
Once you are logged into your Orbi router if you manually type this address in the URL, http://orbi login.net/QOS_main.htm, you can get to several pages that have more options for setting QOS priorities.
My questions is, do these priorities even work? I have set several priorities, from "normal" to "highest", for various MAC addresses and the LAN ports but I don't know if they are even doing anything on my Orbi router. Are they?
On the first page you can seemingly enable or disable WMM and turn "Internet access QOS" on or off. WMM is ebabled by default and Internet access QOS seems to be turned off by default. I left WMM enabled and turned Internet access QOS on becuase I assumed that if I did not turn it on the priorities I set would have no effect (assuming that they might work at all).
There is also an an option to "Enable upstream QOS" which does not seemingly work.
At the bottom of the page is a "SETUP QOS RULE" link which brings you to another page where you can delete or edit 30 QOS priorities that are already seeminlgly in place and where you can create new priorities.
I would really appreciate someone from Netgear explaining what is going on with these semingly hidden QOS settings on the Orbo roouter.
Jun 27, 2018Guru - Experienced User
https://community.netgear.com/t5/Orbi/Hidden-Orbi-QOS-settings-Do-they-work/m-p/1598181#M34850
