spatel27
Dec 30, 2019Follower
orbi questions
Hey all, Just set up my Orbi RK13 I believe. Few questions. I am paying for 1 gig speed and my wifi speed test is topping off at 450 mhz. Any ideas? Is this where it will cap out? Als...
SW_
Dec 30, 2019Prodigy
RBK13 max 5GHz WiFi link rate is 866Mbps. Getting 450Mbps over WiFi is considered good already b/c you will unlikely get 866Mbps. Given it's dual band, you will never see gigabit from the Satellite via Ethernet. The only way you get gigabit speed from ISP is through the main Orbi via Ethernet.
