EJBecker
Feb 15, 2021Follower
Orbi questions
Hi there. New to the community.
I tried contacting Netgear support, but haven't been able to reach anyone who can answer my questions. Makes me worried about buying Netgear products if it's this hard to get support.
If I do buy something, it will be the Orbi LRB20, since I'm rural and need a 4g LTE router. My questions are these:
1. What Orbi satellites will work with the LRB20? Of the satellites that are compatible, is there any advantage of one over the other?
2. What SMA LTE antennas will work best with the LRB20?
Thanks to anyone that can help me answer these questions. Netgear phone support has been utterly useless.
1 Reply
EJBecker wrote:1. What Orbi satellites will work with the LRB20? Of the satellites that are compatible, is there any advantage of one over the other?
Paged 4 of the Product Data Sheet shows which AC satellites are compatible with the LBR20
https://www.netgear.com/images/datasheet/orbi/LBR20.pdf
There are a lot of resources on the web explaining how LTE antennas work, such as
There are problem people who can answer from personal experience on the Netgear forum for the LTE product:
https://community.netgear.com/t5/Orbi-LTE/bd-p/en-home-orbi-lte
