vinotinto
Oct 15, 2018Aspirant
Orbi R50 on latest firmware V2.2.1.210 - SUPER SLOW
Orbi with one satellite. Bought May 2017. Running firmware V2.2.1.210. Have Comcast Blast, which is super fast directly, but Orbi is only getting 1 - 4 mbps downloads. Can't even stream properly. Hel...
Oct 15, 2018Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
