Johnhorton1979
Nov 30, 2019Aspirant
ORBI R50 Wifi link speed
Wifi issue with new Orbi R50, When using virgin media superhub 3 i get expected link speed 450mb on wifi, however on the Orbi this drops to 300mb. Mobile phones other devices connect and get full sp...
Dec 01, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Johnhorton1979
Dec 01, 2019Aspirant
Thanks for the response.
The virgin media super hub 3 is set to modem mode and it looks like the orbi is setup in router mode. Would my best option be to set up the Orbi as an AP Instead
- FURRYe38Dec 01, 2019Guru - Experienced User
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Might try mode in router mode and Orbi in AP mode as last resort configuration to try
- Johnhorton1979Dec 01, 2019Aspirant
Thanks for all the suggestions and advice and i have tried everything you advised.
1 - currently have modem mode on the sh3
2 - Router mode on Orbi 50
3 - Mobile devices etc all connecting a good speeds
4 - Imac and macbook pro when connected to the sh3 as standard config get correct link rate, however as soon as these are connected to the orbi i only get link speed of 300mbps.
Wow, i have just come off support with Netgear over an hour long and still no closer, they are now saying that i need to contact apple to change settings on laptop ?
I just do not understand where there is a difference
https://prnt.sc/q4t9n3 - ORBI 50
https://prnt.sc/q4ta6e - SH3
I have changed channels and done all the recomended setttings the laptop clearly supports the speed under the SH3 so what is stopping it reaching this and all other devices are ?
hope someone can help
regards
john
