Johnhorton1979
Nov 30, 2019Aspirant
ORBI R50 Wifi link speed
Wifi issue with new Orbi R50, When using virgin media superhub 3 i get expected link speed 450mb on wifi, however on the Orbi this drops to 300mb. Mobile phones other devices connect and get full sp...
Dec 02, 2019Guru - Experienced User
So heres what I found with my MBP2018, It's seeing at least 520Mbps. however I noticed the speed drop to about 350Mbps while just stting there. I then kicked off a speedtest with Ooklas speed test app and watch as the test ran that the wifi rate went bsck up to 520Mpbs. I was about 4 feet away from the RBR line of sight. All this was in 10.14. I saw 866Mpbs when I booted to 10.15 on the MBP and same drop off behavior. So I think the wifi drivers on the MBP are probably slowing the rate if nothing is flowing thru the connection. Are you having any data flow thru the connection when your looking at the connection rate? Or is the 300Mbps seen all the time regardless of data flow or not? Try this to be sure.
My Mac Mini 2012 barely go anything up to 270Mbps. However is farther away from the RBR and not in line of site. Not sure how good the radios on the Mini are though I had seen 450Mbps before with it. It mostly wired to the network anyways.
v40 here as well.
- Johnhorton1979Dec 03, 2019Aspirant
On the macbook in the same room the connection stays at 300mbps regardless if data is running through.
I have just tested my Imac in the office garden this starts at 1300mbps and drops to 879mbps.
When running speed tests on the imac in the garden results are not great 150mbs was previously hitting the full speeds with the SH3
Wasnt expecting such a drop to be honest been a nightmare. really cant think of anything else to do as everything worked fine under under the sh3 and if i unplu everything and go back to old set up everything works something on the orbi is causing this imo
- Johnhorton1979Dec 03, 2019AspirantThe more I think about it the more I think it’s an issue with the Apple Macs. All windows based. iPhones and android devices are working to the full capabilities
- FURRYe38Dec 03, 2019Guru - Experienced User
I would presume that your Orbi maybe faulty. Since you've tired other FW versions, leads me to think this system is just bad and needs replaced or go with something else.
- Johnhorton1979Dec 03, 2019AspirantI have been tempted to return as I feel it should work correctly with the Apple products. Or try something else. As yours are working as they should so should others.
