alexandernunes
Jul 12, 2017Initiate
Orbi random rebooting
I have just bought an ORBI RBK43 AC2200 a couple of weeks ago. After the first configurations, it means just setting up a new SSID name and password for Orbi Wi-Fi, the router unit started to drop off...
DarrenM
Jul 13, 2017Sr. NETGEAR Moderator
Hello alexandernunes
I would factory reset the unit by holding the reset button for 10 seconds see if that behavior changes if not I suggest contacting support.
http://www.netgear.com/support/contact.aspx
DarrenM
- alexandernunesJul 25, 2017Initiate
Hi,
I have reseted the unit to factoy default settings, but it didn't work either. The unit is unable to update the firmware as a message on app says.
