netmaster2020
Oct 01, 2017Follower
Orbi randomly dropping internet connection despite V2.0.0.74 update
Hi all, I recently purchased an RBK50 Orbi + satellite router but it is dropping internet connection randomly despite updating firmware to the latest V2.0.0.74. This is more often the case upon...
resonance120
Oct 06, 2017Initiate
I have DISABLED the Daisy-Chain Topology in V2.0.0.74, and connection has become so much more stable. Have a try!
- JustMakeItWorkOct 06, 2017Apprentice
Yep I disabled that too. In fact I disabled everything. At this point I just need to keep the thing running. I don't care if its any faster if its shutting down all the time.
- DCP4971Oct 07, 2017Luminary
Thanks for the suggestion, giving that a whirl! Only have one satellite can't do any harm - famous last words with Orbi..
- washOct 13, 2017Aspirant
I'm having the same issue and I just bought my Orbi yesterday 10/13/2017. Come on Netgear you guys need to do something. Stop blaming everything on the update and take action!!
- DCP4971Oct 13, 2017Luminary
Hi, I had a call from a Netgear engineer the other day having raised a support ticket and created merry hell over this. He was adamant that he knew how to solve it.
The issue does seem to be the firmware update and the introduction of the Enable Daisy Chain Topology. In my case, I only have one satellite, so don't need it to be trying to daisy chain, but this was enemy,ed by default when applying the firmware update.
I had already followed someone's advice on the forum and disabled this (Advanced Setup/Wireless Settings) and its been solid as a rock ever since. The Netgear engineer also suggested disabling Enable fast roaming (I assume its related to the Daisy Chain).
Suggest giving this a try, it's made a world of difference to me at least.
Good luck.
