netmaster2020
Oct 01, 2017Follower
Orbi randomly dropping internet connection despite V2.0.0.74 update
Hi all, I recently purchased an RBK50 Orbi + satellite router but it is dropping internet connection randomly despite updating firmware to the latest V2.0.0.74. This is more often the case upon...
sleepr88
Jan 11, 2018Apprentice
Since I can't use my Pixel 2 XL or my Nexus 6P on wifi with the Orbi(obviously with current issue) I started using my old Note 3 to play games on. Well it also makes the Orbi system REBOOT every time it wakes up! I wish Netgear would just refund me for this junk system because it doesn't seem like they will ever fix it?
Any suggestions anybody?
Charleem
Jan 11, 2018Guide
Just out of interest, could you enable a guest network and try connecting to that? I'm wondering if the issue is the smart connect that puts devices into the best signal and speed, since you can't do it manually, but you can with the guest WiFi.
