netmaster2020
Oct 02, 2017Follower
Orbi randomly dropping internet connection despite V2.0.0.74 update
Hi all, I recently purchased an RBK50 Orbi + satellite router but it is dropping internet connection randomly despite updating firmware to the latest V2.0.0.74. This is more often the case upon...
lioneljw
Jan 22, 2018Aspirant
I am having the same issue as well on the latest 2.1.2.18 firmware. I have had my cable connection replaced and they have tested everything including the modem and been out to verify its all working but still every 20 or so minutes the router loses connection and goes into detecting internet mode and then eventually reconnects with all the same settings.This issue started with the 2.0.0.74 update but, at least in my case, it seems actually worse under 2.1.2.18 as its doing this behavior more frequently. Almost at the point of returning my Orbi and trying another solution :(
JustMakeItWork
Jan 22, 2018Apprentice
Issue is possibly not related to Google hardware at all. I have run tests in a Google-free environment and the problem has persisted even with the latest firmware. Since I've migrated to other hardware the only things on the Orbi are several iPhones and a Macbook Pro. The rest of the hardware is on a Google router now. Still failing under those circumstances so I would assume that its related to something that was introduced in 2.0.0.74 (the Disney Circle stuff was the only change that I noticed) and not specifically Google gear unless somehow the Orbi is letting Google devices connect to it somehow. This AppleNet is entirely isolated from the rest of the world all the way to the Internet gateway itself.
