netmaster2020
Oct 01, 2017Follower
Orbi randomly dropping internet connection despite V2.0.0.74 update
Hi all, I recently purchased an RBK50 Orbi + satellite router but it is dropping internet connection randomly despite updating firmware to the latest V2.0.0.74. This is more often the case upon...
linkwrt
Jan 23, 2018Guide
Step 1 update your firmware
Step 2 reset to factory default
Step 3 configure again your router. Let defaults options. Is the best solution and always is working.
You don't need to enable beamforming or mu-mimo.
- POSEIDON7902Jan 23, 2018ApprenticeIf you have any Android phones, update play services. If the full release isn't available, follow the guide I posted to download the beta. It fixed the problem for myself and several others I know as well as being documented to fix other manufacturers as well. Do that before you do anything else. Then if you still have a problem try other methods.
- dneumannjrJan 23, 2018Tutor
Poseidon,
Can you verify what playstore version is running for you that works? I am currently on 8.5.46.W-all but have not turned my wireless back on. Have had no issues since I turned my wireless off on the phone. I also signed up for BETA but have not recevied a notification that an install has occured. Thanks for your help.
- POSEIDON7902Jan 23, 2018ApprenticeIt's not playstore. It's play services. Here's the version I'm on.
