netmaster2020
Oct 01, 2017Follower
Orbi randomly dropping internet connection despite V2.0.0.74 update
Hi all, I recently purchased an RBK50 Orbi + satellite router but it is dropping internet connection randomly despite updating firmware to the latest V2.0.0.74. This is more often the case upon...
POSEIDON7902
Jan 23, 2018Apprentice
If you have any Android phones, update play services. If the full release isn't available, follow the guide I posted to download the beta. It fixed the problem for myself and several others I know as well as being documented to fix other manufacturers as well. Do that before you do anything else. Then if you still have a problem try other methods.
dneumannjr
Jan 23, 2018Tutor
Poseidon,
Can you verify what playstore version is running for you that works? I am currently on 8.5.46.W-all but have not turned my wireless back on. Have had no issues since I turned my wireless off on the phone. I also signed up for BETA but have not recevied a notification that an install has occured. Thanks for your help.
- POSEIDON7902Jan 23, 2018ApprenticeIt's not playstore. It's play services. Here's the version I'm on.
- POSEIDON7902Jan 23, 2018ApprenticeDouble post
- POSEIDON7902Jan 23, 2018ApprenticeHere's the walk through so you don't have to search.
https://9to5google.com/2018/01/18/download-google-play-services-fix-update-google-home-chromecast-wi-fi-problems/
