PebbleChamp
Mar 20, 2021Tutor
Orbi randomly stops traffic to devices
Orbi has worked great since I bought it a couple of years ago, but since about two weeks ago I’ve had problems. Randomly traffic all of a sudden stops going to devices, but any devices currently activ...
Mar 20, 2021Guru - Experienced User
Is Traffic Meter enabled?
- PebbleChampMar 22, 2021TutorModem is Arris Surfboard SB6183 (P/N: 592431-003), but as I mentioned in the initial post, I also tried the Xfinity X1 router in bridge mode and had the same issues, so I took it back.
Traffic Meter is off.
Just updated FW to v2.7.2.104. Yes, I did a full factory reset.
This started before I updated the firmware; I don’t know the exact FWv, but I’m certain it was v2.5x.x.
Anyone??? It looks like there are others with the same issue. Did NetGear put an Easter egg in these so that we would have to upgrade? 😡
