PebbleChamp
Mar 20, 2021Tutor
Orbi randomly stops traffic to devices
Orbi has worked great since I bought it a couple of years ago, but since about two weeks ago I’ve had problems. Randomly traffic all of a sudden stops going to devices, but any devices currently activ...
AYANUSER
Mar 21, 2021Tutor
V2.7.2.104
My RBR50 is having same issue since 2-3 weeks ago. Is this related to newest firmware?
PebbleChamp
Mar 22, 2021Tutor
I don’t think it’s related to the newest firmware b/c it started happening to me the same timeframe (2-3 weeks ago) and I was on FW v2.5.x.x.
I was hoping that updating to the latest FW would fix the issue, but it didn’t.
- FURRYe38Mar 22, 2021Guru - Experienced User
I was hoping that updating to the latest FW would fix the issue, but it didn’t.- D18GEMar 23, 2021Star
Thanks for including the link to the NTP discussion. I did have Traffic Meter enabled and disabled as suggested. Will report back if this solves the problem.
- FURRYe38Mar 23, 2021Guru - Experienced User
Kewl. Let us know. You should be good now. NG is aware of it. :smileywink:
PebbleChamp
You may be correct. In my case I had just updated the firmware to V2.7.2.104 a few days previous to DST which caused me to think firmware as everything had been stable before. Interestingly, I never had as issue with DST change previously so jury is still out in my mind whether this is firmware or DST. I did disable Traffic Meter as per Bianca's suggestion in the Daylight Savings Time, NTP, DNS Issues thread that FURRYe38 linked. Fingers crossed.
Be sure to do a backup configuration on the RBR for safe keeping. Saves time if a reset is needed.
- PebbleChampMar 23, 2021TutorHadn’t even thought of that. Thanks for the reminder; I’ll download a config for it now!
- D18GEMar 24, 2021Star
Update:
Orbi router has not needed a reboot in over 24 hours after disabling Traffic Meter. The only other change I made was to change the NTP server to one of the NIST servers. So far it would appear that Traffic Meter is the culprit if you also have DST enabled. Will update again in 24 hours or so.
- FURRYe38Mar 24, 2021Guru - Experienced User
Good to hear.
Enjoy.
D18GE wrote:Update:
