PebbleChamp
Mar 20, 2021Tutor
Orbi randomly stops traffic to devices
Orbi has worked great since I bought it a couple of years ago, but since about two weeks ago I’ve had problems. Randomly traffic all of a sudden stops going to devices, but any devices currently activ...
PebbleChamp
Mar 22, 2021Tutor
I don’t think it’s related to the newest firmware b/c it started happening to me the same timeframe (2-3 weeks ago) and I was on FW v2.5.x.x.
I was hoping that updating to the latest FW would fix the issue, but it didn’t.
Mar 22, 2021Guru - Experienced User
- D18GEMar 23, 2021Star
Thanks for including the link to the NTP discussion. I did have Traffic Meter enabled and disabled as suggested. Will report back if this solves the problem.
- FURRYe38Mar 23, 2021Guru - Experienced User
Kewl. Let us know. You should be good now. NG is aware of it. :smileywink:
