tomeven
Jul 24, 2018Aspirant
Orbi RB 50 - problems with connecting to websites - BRS_wanlan_conflict
When my Orbi system is used I often get a pop-up message which asks for login information to websites, or message that says no such webpage exist
The web adress is followed by - BRS_wanlan_conflic...
Jul 24, 2018Guru - Experienced User
Ok, so this the DWR is a router as well so you have a double NAT condition.
Couple of options,
1. Configure the DWR for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact D-Link for help and information in regards to the DWR being bridged correctly.
2. If you can't bridge the DWR, disable ALL wifi radios on the DWR, configure the DWRs DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the DWR and connect the Orbi router to the DWR, LAN to LAN and configure AP mode on the Orbi router.
- AC641Jul 24, 2018Luminary
The DWR 956 is a 4G Router with an option to operate in Bridge Mode. I assume you are operating it in Bridge Mode with the Orbi acting as the Router. If not then do so (assuming that you want to use the Orbi as the Router) and switch off the WiFi of the DWR device. If you want the DWR to act as the Router then you need to switch the Orbi Router to AP (Access Point) mode. Also ensure you have the Ethernet cable from the DWR 'modem' into the yellow port of the Orbi Router.
