Noiprocs
Aug 07, 2019Tutor
ORBI RB 50 - Sign in , your connection to this site is not private, and he asks Usename and paswoord
I installed the Orbi RBR50 and 1 satellite: It works correctly But Since I instaleld this, I can not visit all sites, it blocks on some sites, on my pc but also on my Ipad. If I switch to another ne...
- Aug 07, 2019
Let us know how it goes...
Aug 07, 2019Guru - Experienced User
Is the Orbi system operating in Router or Access Point mode?
What browser are you using?
This a wired PC or wireless device?
Happens with all devices when visiting web sites?
Noiprocs
Aug 07, 2019Tutor
Hello
Firts thanks for your raection : as I mentionned, I am not a specialist
Firmware version is 2.3.1.60, I updated when I installed
- PC and Tablet are working with WIFI
- Sotware I used is Chrome on PC
- Chrome and Quant on Ipad
it happens not on all site, but it happens on a lot of site as Autoscout,...
it is also new, I had this never before and we are "connected" since 20 years ;-)
We are in Belgium and I connect the Orbi to the Router we have from the telecom company (Proximus).
I use teh Orbi as Router and the satelliet as accespoint
The router from the telecom company ( Proximus)
B-Box 3
- Mémoire flash 128 MB
- Mémoire RAM 256 MB
- Processeur : 400 Mhz Dual Core
- Port DSL : 1 port RJ11
- Interface LAN : 4 port RJ45 1 GBps
- Interface WAN : 1 port RJ45 1 GBps
- Wi-Fi : Dual band : 02.11b/g/n 2.4 GHz et WiFi 02.11a/n 5 GHz |
- Port USB : 2 (actif
- Norme IP : IPv4 et IPv6
I am not sure I fully answer to your question, sorry
Guy
- FURRYe38Aug 07, 2019Guru - Experienced User
Your ISP modem may already have a router built in, If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI would suggest try configuring the RBR for AP mode seen in Option #3...
