Noiprocs
Aug 07, 2019Tutor
ORBI RB 50 - Sign in , your connection to this site is not private, and he asks Usename and paswoord
I installed the Orbi RBR50 and 1 satellite: It works correctly But Since I instaleld this, I can not visit all sites, it blocks on some sites, on my pc but also on my Ipad. If I switch to another ne...
- Aug 07, 2019
Let us know how it goes...
Noiprocs
Aug 07, 2019Tutor
Hello
Firts thanks for your raection : as I mentionned, I am not a specialist
Firmware version is 2.3.1.60, I updated when I installed
- PC and Tablet are working with WIFI
- Sotware I used is Chrome on PC
- Chrome and Quant on Ipad
it happens not on all site, but it happens on a lot of site as Autoscout,...
it is also new, I had this never before and we are "connected" since 20 years ;-)
We are in Belgium and I connect the Orbi to the Router we have from the telecom company (Proximus).
I use teh Orbi as Router and the satelliet as accespoint
The router from the telecom company ( Proximus)
B-Box 3
- Mémoire flash 128 MB
- Mémoire RAM 256 MB
- Processeur : 400 Mhz Dual Core
- Port DSL : 1 port RJ11
- Interface LAN : 4 port RJ45 1 GBps
- Interface WAN : 1 port RJ45 1 GBps
- Wi-Fi : Dual band : 02.11b/g/n 2.4 GHz et WiFi 02.11a/n 5 GHz |
- Port USB : 2 (actif
- Norme IP : IPv4 et IPv6
I am not sure I fully answer to your question, sorry
Guy
Aug 07, 2019Guru - Experienced User
Your ISP modem may already have a router built in, If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would suggest try configuring the RBR for AP mode seen in Option #3...
- NoiprocsAug 07, 2019Tutor
Thanks for the very fast reaction :-)
i will first try to by pass the router...
if it is not working, I will do your proposal 3
I come back after, itwoulb be on sunday
Many thanks
Guy
- FURRYe38Aug 07, 2019Guru - Experienced User
- NoiprocsSep 01, 2019Tutor
Dear FURRye38
Thank you very much for your quick support and sorry to answer you so late ...
I chose your proposal to use the Orbi RB 50 as an access point and its satellite as well.
My perception is that my Wifi is slightly worse ...
Is this normal?
but I now have access to all the site.
I will try later on another solution that you have proposed.
thanks again for your help, i really needed it ;-)
Guy
