Noiprocs
Aug 07, 2019Tutor
ORBI RB 50 - Sign in , your connection to this site is not private, and he asks Usename and paswoord
I installed the Orbi RBR50 and 1 satellite: It works correctly But Since I instaleld this, I can not visit all sites, it blocks on some sites, on my pc but also on my Ipad. If I switch to another ne...
- Aug 07, 2019
Let us know how it goes...
Noiprocs
Aug 07, 2019Tutor
Thanks for the very fast reaction :-)
i will first try to by pass the router...
if it is not working, I will do your proposal 3
I come back after, itwoulb be on sunday
Many thanks
Guy
Aug 07, 2019Guru - Experienced User
- NoiprocsSep 01, 2019Tutor
Dear FURRye38
Thank you very much for your quick support and sorry to answer you so late ...
I chose your proposal to use the Orbi RB 50 as an access point and its satellite as well.
My perception is that my Wifi is slightly worse ...
Is this normal?
but I now have access to all the site.
I will try later on another solution that you have proposed.
thanks again for your help, i really needed it ;-)
Guy
