jmheckman
Nov 25, 2018Aspirant
Orbi RB-50 and printing
Recently, I lost the ability to print. My HP 8600 printer tells me that my computer and printer are on different networks, but both devices are on the same Orbi network with the same name. I have r...
- Nov 30, 2018
Thanks, everyone for your help in solving my problem. At the risk of sounding stupid, I wanted to come clean and let you all know that my printing problem is fixed. Somehow during renovation in our family room an ethernet cable from the ORBI got plugged back into the modem creating a loop. Everything I tried showed me that I had two networks with the same name and I knew I didn't. But the loop created the second network. As soon as I unplugged the additional ethernet cable, all is good.
poswald
Nov 25, 2018Guide
My suggestion is to check to see if your Orbi has decided to use channel 12, 13 or 14. Some printers don't have the ability to see these channels. See this thread:
https://community.netgear.com/t5/Orbi/WiFi-printer-problem/m-p/1562633#M29951
I had a problem with a printer and forcing the Orbi to use a specific channel fixed it for me.
- jmheckmanNov 26, 2018Aspirant
Thanks. I forced the ORBI to channel 11 but still cannot print.
