jmheckman
Nov 25, 2018Aspirant
Orbi RB-50 and printing
Recently, I lost the ability to print. My HP 8600 printer tells me that my computer and printer are on different networks, but both devices are on the same Orbi network with the same name. I have r...
- Nov 30, 2018
Thanks, everyone for your help in solving my problem. At the risk of sounding stupid, I wanted to come clean and let you all know that my printing problem is fixed. Somehow during renovation in our family room an ethernet cable from the ORBI got plugged back into the modem creating a loop. Everything I tried showed me that I had two networks with the same name and I knew I didn't. But the loop created the second network. As soon as I unplugged the additional ethernet cable, all is good.
ekhalil
Nov 26, 2018Master
jmheckman wrote:
Recently, I lost the ability to print. My HP 8600 printer tells me that my computer and printer are on different networks, but both devices are on the same Orbi network with the same name. I have reset all equipment, deleted the printer software and even forced the computer and the router to log into the router using the same bandwidth. Still no printing capabilities. I unplugged the Orbi satellite and forced both devices to log into the main router. Still nothing. HP says it's an Orbi issue. Any suggestions?
Can you please list the IP addresses assigned to your computer and that for your printer. Please check directly in the computer (under network settings) and in the printer (under network settings).
I suspect that you have 2 DHCP servers in your network providing IP address asignments.
