Prutten
May 21, 2019Aspirant
Orbi RB 50 Iphone disconnects
Hi,
I have been using my RBK 50 and its Satelite for 1 year and it has worked beautifully, never been so happy with a router before.
I Idecided to move to new house and brought my Orbi w...
May 23, 2019Guru - Experienced User
No.
No.
Prutten
Jul 03, 2019Aspirant
FURRYe38, Hi!
Continuing the thread started ages ago :smileyvery-happy:
-What channels are you using? Auto?
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
2.4Ghz Set to 1
5Ghz Set to 36
- What WPA security modes are you using?
WPA2-PSK [AES]
- Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Done
- Try disabling the following and see:
Daisy Chain, Done
Fast Roaming, Done
IPv6 Done
Set 20/40Mhz Coexistence to 40Mhz only.
Cant set this setting...its only a checkbox
Save settings and reboot the router and satellite(s).
Still facing glitches
- FURRYe38Jul 03, 2019Guru - Experienced User
Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307. and Set 20/40Mhz Coexistence to 40Mhz only. Uncheck the check box.
I haven't seen any issues with my iPhone 6sP...
