Prutten
May 21, 2019Aspirant
Orbi RB 50 Iphone disconnects
Hi,
I have been using my RBK 50 and its Satelite for 1 year and it has worked beautifully, never been so happy with a router before.
I Idecided to move to new house and brought my Orbi w...
Prutten
Jul 05, 2019Aspirant
I have problems with my mac pro as well, not only my ios anymore.
I have really big problems on this network of some reasons hence when playing my Sonos my songs disconnects and wifi releases.
Never experienced problems like this before
Prutten
- FURRYe38Jul 07, 2019Guru - Experienced User
I believe you may have a wifi router infront of the Orbi system already at your ISP Modem, if so,
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
