CAG61
Mar 06, 2020Tutor
Orbi RB20 Not showing all attached devices
I have noticed that my Attached device list fails to show all devices. How do I know, checked my Samsung S8. Connected with IP address, checked the Orbi... no device on that IP address or on any...
Retired_Member
Mar 06, 2020Where are you seeing this...Attached device list...?
On the App?
- CAG61Mar 06, 2020Tutor
on the webpage for the device. I don't use the app.
- Retired_MemberMar 06, 2020
CAG61 wrote:on the webpage for the device. I don't use the app.
OK...like with most problems of this nature....has the webpage device listing ever looked good for you? How long have you had your Orbi system? Any changes?
Hardware, FW, device, etc?
Yes, the device page has looked correct.
I had to do a factory reset to correct 2.4 turning off. it works now, but only with Auto and not specific channel.
I haven't checked every device but the number is close to what I normally see.
