Tonichi613
Sep 30, 2019Aspirant
Orbi RB20 quit after detaching-re attaching them to modem
Hi. Do you guys have any idea on what's going with my ORBI RBR20 quitting after doing some cable management?! Did try rebooting them but it always seem to quit. The other two sattelites were detected ...
CrimpOn
Sep 30, 2019Guru - Experienced User
Please describe how your RBR20 is set up.
- What is the Orbi connected to with ethernet cable from the WAN (yellow) port?
(Brand and model number) - Please what "cable management" was done?
- What does "quitting" mean? i.e. the WiFi network no longer appears? devices can connect, but get no internet?
- Do you have a computer (desktop, laptop) that can be connected to the RBR20 with an ethernet cable?
Tonichi613
First, Thank you for the reaponse.
- FROM CABLE BOX (COAX) ATTACHED TO THE BACK OF MODEM THEN ETHERNET CABLE TO WAN OF MY ORBI RBR20
What is the Orbi connected to with ethernet cable from the WAN (yellow) port? - YES
(Brand and model number) - NETGEAR CM1150V
Please what "cable management" was done? - JUST ZIP TIENG CABLES TO GET THOSE WIRES TIDY. RE-ATTACHED THEM BACK THE WAY IT WAS WORKING DAY 1 THAT I GOT THE MODEM. DID THEM BEFORE, MOVED LOCATION FROM DOWNSTAIRS TO UPSTAIRS AND HAD NO ISSUES NOT TILL YESTERDAY NIGHT
What does "quitting" mean? - QUITTING MEANS TO ME THAT MY ROUTER STOPPED WORKING AS USUAL
i.e. the WiFi network no longer appears? devices can connect, but get no internet? - WIFI SIGNAL AND NETWORK STILL APPEARS ON MY DEVICES BUT CANNOT CONNECT ON THE INTERNET
Do you have a computer (desktop, laptop) that can be connected to the RBR20 with an ethernet cable? - YES
