iamallright
Jun 15, 2020Follower
Orbi RB40 keeps blocking certain devices
RB40 with two satellites (RB20) seems to have a hard time staying connected to specific devices, even with the satellite next to the device. The system "Blocks" acess often and when I try and change...
Jun 16, 2020Guru - Experienced User
