Jaxtal
May 04, 2023Aspirant
Orbi RB50 Admin Login Issue
Hoping the community can help. I tried logging into my Obri to adjust some settings. It prompted my for the username/pw and I put in what I thought I had set up. No dice. It asked me to put in my ser...
CrimpOn
May 04, 2023Guru - Experienced User
When the router is Factory Reset, the admin credentials should be "admin" and "password"
Is that what you tried?
Jaxtal
Yes, and that is what is on the bottom of my Orbi.
- CrimpOnMay 04, 2023Guru - Experienced User
Yes, that is correct.
How are you connecting to the router?
(wired PC or laptop? mobile device after logging into Orbi WiFi network?)
I seem to recall that the last time I did a Factory Reset and connected with a wired computer, that it didn't ask for a login at all, and went immediately to the setup process.
- JaxtalMay 04, 2023Aspirant
PC hardwired into satellite.
Well, strange. Definitely saw the power LED blink Amber.
The WiFi SSID changes to the SSID printed on the product label.
Connect a web browser and the credentials box pops up.
Fill in "admin" and "password" and it gets rejected?
Damn
