Jaxtal
May 04, 2023Aspirant
Orbi RB50 Admin Login Issue
Hoping the community can help. I tried logging into my Obri to adjust some settings. It prompted my for the username/pw and I put in what I thought I had set up. No dice. It asked me to put in my ser...
Jaxtal
Yes, and that is what is on the bottom of my Orbi.
CrimpOn
May 04, 2023Guru - Experienced User
Yes, that is correct.
How are you connecting to the router?
(wired PC or laptop? mobile device after logging into Orbi WiFi network?)
I seem to recall that the last time I did a Factory Reset and connected with a wired computer, that it didn't ask for a login at all, and went immediately to the setup process.
- JaxtalMay 04, 2023Aspirant
PC hardwired into satellite.
- CrimpOnMay 04, 2023Guru - Experienced User
Well, strange. Definitely saw the power LED blink Amber.
The WiFi SSID changes to the SSID printed on the product label.
Connect a web browser and the credentials box pops up.
Fill in "admin" and "password" and it gets rejected?
Damn
- JaxtalMay 05, 2023Aspirant
That's correct. Really don't know what to do, but I appreciate you replying and trying to help, but I have done everything the support documents says to do.
