GregOrbi
Jan 09, 2019Follower
Orbi RB50 erreur 404 et MAJ appli iOS impossible
Bonjour, j’ai installé mon orbi en mode routeur avec un satellite. J’ai désactivé le wifi de la box (a l’aide du bouton sur la face de la box). J’ai en revanche du laisser deux accessoires, un branché...
ekhalil
Jan 09, 2019Master
GregOrbi wrote:
Hello, I installed my orbi in router mode with a satellite. I disabled the wifi box (using the button on the front of the box). I have to leave two accessories, one connected to the box internet and the other connected to the box tv (different piece) because without it impossible to operate the box tv.
Since then, I have two problems:
- 404 error on some web pages
- I can not download / update the apps on my iPhone.
Can you tell me how to solve these two problems please?
Thank you
Your ISP Router (Internet Box) is still a router (even though you disabled wifi on it) and then you added another router (Orbi) so there you will have two sources for IP addresses and this will just give you different headaches.
Please do one of the following:
1) Bridge the ISP router or configure it's DMZ to go to the IP address assigned to Orbi in the router.
2) If the router does not allow you to do this, then set Orbi in AP mode instead (using the Orbi GUI on orbilogin.com). Please see below how to set Orbi in AP Mode:
