Dp1999
Dec 25, 2017Aspirant
Orbi RB50 multiple SSID visible
I have one computer connected via LAN to the orbi router. This connection shows SSID Orbi66 2. The other devices (but also this computer) have wireless connections to the router/satellite. This conne...
DarrenM
Dec 27, 2017Sr. NETGEAR Moderator
I would try to first power cycle all the orbi units see if that works.
DarrenM
- Dp1999Dec 28, 2017Aspirant
If you mean switching on and off all devices than this does not work.
- guzzijasonDec 28, 2017Apprentice
If you haven't yet, I would try re-syncing the satellite to the router.
