Dp1999
Dec 25, 2017Aspirant
Orbi RB50 multiple SSID visible
I have one computer connected via LAN to the orbi router. This connection shows SSID Orbi66 2. The other devices (but also this computer) have wireless connections to the router/satellite. This conne...
DarrenM
Dec 27, 2017Sr. NETGEAR Moderator
I would try to first power cycle all the orbi units see if that works.
DarrenM
Dp1999
Dec 28, 2017Aspirant
If you mean switching on and off all devices than this does not work.
- guzzijasonDec 28, 2017Apprentice
If you haven't yet, I would try re-syncing the satellite to the router.
