CharleyRose
May 01, 2021Aspirant
Orbi RB50 Network Problem
I have the Orbi 3000 Router with 2 Satellites. If I'm on a Computer connected to a Satellite by Wifi or Ethernet, I'm unable to see devices that are connected to the main Router. I have a NAS conne...
CharleyRose
May 02, 2021Aspirant
Yes I see all devices listed in the Orbi Web Interface with their corresponding Satellite or Router indicated. After looking further I think I'm only having this issue with Satellite 2. When I'm connected to Satellite 1 I do see my NAS that's connected to the main router.
CrimpOn
May 02, 2021Guru - Experienced User
CharleyRose wrote:Yes I see all devices listed in the Orbi Web Interface with their corresponding Satellite or Router indicated. After looking further I think I'm only having this issue with Satellite 2. When I'm connected to Satellite 1 I do see my NAS that's connected to the main router.
It is so frustrating when a problem exists that should never happen. Deleting, doing a factory reset on the satellite, and readding it is not nearly the amount of effort as resetting the router. I would probably try that. OR.... if getting to the NAS is required from only one location, swap the satellites?
